RCD tripping Continuity test | on ElectriciansForums
Discuss RCD tripping Continuity test in the UK Electrical Forum area at ElectriciansForums.net
C
coatesykid
Hi, am doing a continuity test on living room light, downstairs MCB off, last light in circuit, incoming to light disconnected, disconnect switch twin and earth, cross connected Earth and neutral in switch, did a continuity test at light and the RCD trips.
Any help appreciated, only thing I could think of is that the current sent from tester is leaking out the switch cable into another cable and tripping RCD.
please Expand LOL
please Expand LOL
I Made a mistake in first post said tested natural and earth ment switch live and earth.
Ill try and explain better twin and earth which includes switch live, live and earth, from switch to ceiling rose disconnected at both ends so its isn't part of the circuit, continuity between live and switch live good, continuity between earth and switch live trips RCD
Reply to RCD tripping Continuity test in the UK Electrical Forum area at ElectriciansForums.net
In my opinion replacing the consumer unit and waiting to see which RCBO trips is not a good fault finding technique. If the lighting circuit...
davesparks
Seen this where T&E has been fixed with a flat bend of too tight a radius.
2 3
