RCD tripping problem | Page 2 | on ElectriciansForums
Discuss RCD tripping problem in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
their going to give me a phone when the guy arranges to come out. they have had issues with the freezer in the past and feel they are getting the run around. i'll ramp test it at the same time.
Another good reason for having (if at all possible) the freezer(s) on a non RCD protected circuit (as in protect the cabling one of the other ways!).
The few times it's been possible to surface run the circuit and then use a flex outlet (not socket) has made sense to me. My neighbour came home two weeks ago and her freezer had a £100 quids worth of mush in it.
Was a rusty light fitting in garage (not touched for 20 years) just suddenly gone short circuit.
Would it be a Samsung freezer by any chance, been having a few problems recently with their kit. Found a fault on a fridge / freezer and rang Samsung to query what I found they came out and fixed it FOC due to a recall on some parts, original fault I found and queried is still not resolved
no, it's an AEG but it was initially over heating and then it was getting too cold. both problems fixed but since then the RCD is tripping.
Reply to RCD tripping problem in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
In my opinion replacing the consumer unit and waiting to see which RCBO trips is not a good fault finding technique. If the lighting circuit...
davesparks
Just an update for anyone interested, I got another rod in outside today, which has lowered the Zs db to a more healthy 53ohms. The oven elements...
4K
