Evening, came across a fault today on a new board that’s been fitted by a previous electrician. Split load dual RCD 6 way Hager board, when a fused spur is switched on or when the boiler starts up the RCD trips but the circuit is on the other RCD. Have checked the all wiring at the DB and all is ok. The previous board was a old wylex 100ma RCD board and never tripped.
