Rcd trips after installing rcd | Page 2 | on ElectriciansForums
Discuss Rcd trips after installing rcd in the UK Electrical Forum area at ElectriciansForums.net
Dear all,
Really shattered today. It is old house. Fusebox vey old type. I replaced it with a new consumer with rcd. However rcd keeps tripping for all the sockets circuits. Upstairs lights fine. Downstairs generall fine but rcd tripps when I turn on kitchen lights.
I disconnect earth for all socket circuits but nothing changes. Tested all continuity and insulation all looks fine. Pulled out all appliances from sockets but rcd still trips. Really shuttered. Getting late and no time for further check. Will go back in a few days.
Any ideas of whats happening?
Any idea will be highly appreciated.
Regrds
He did say repeatedly in the Op that he was shattered and so he may not have been thinking clearly at the time of posting and may have been panicking a bit whilst doing the installation and attempting to fault find. If things were going badly anyway this may have been a bit too much. I know I have got to the end of the day and gone "ahhhhhh" as the very last thing goes wrong.
Removal of the earths is a sort of logical but not a sensible approach to finding out if it is a wiring fault to earth rather than a parallel live conductor path fault.
I hope that now he has had a chance to think about it he will be able to come back and let us know the fault and resolution.
It could be the neutral busbar link was still in, but probably not based on the effects seen.
I did wire up a board whilst the customer was talking to me a lot and moved a leg of the ring instead of the spur off the ring over to the other ring and got some good RCD tripping there. This did throw me for a few minutes.
According to his profile he's not been back on since posting ..... unless he's viewing the thread when not logged in.......... then we will never know.
I suspect we've ALL posted in haste and regretted aspects of it later, but this is all very basic stuff ...... so fingers crossed he'll update us soon......
More chance of me giving up beer
Think with all the bad press, I suspect the OP is going to be a bit reticent in replying.
Bad press???? Nothing to do with the clueless original post that clearly demonstrates that the "electrician" in question has not the first idea of what he is no doubt taking good money off some poor unsuspecting customer for then? And the chances of him/her coming back on here and contributing to the thread? Non existent, as usual!
Well, the original post was a bit vague, Ill give you that. Perhaps if the OP does come back, we might get some clarification, before we make assumptions.
Try giving the guy some professional advice if that's what you are and not sarcastic bull****.
OK. Well, I am not sure what the "guy" in question's qualifications or experience are but I suspect he is also some "Domestic installer", whatever the hell that is, either way it would be to go and get some proper qualifications, as he obviously has no idea what he is doing. Presumably he is charging some poor unsuspecting customer for the benefit of having his dubious talents on their premises, fannying about and not even having the experience or ability to diagnose what is probably a simple, obvious mistake he has made, as has been pointed out to him. This guy has put himself forward to the public as a competent person who has taken on the task of replacing this poor sods consumer unit, and he obviously has no idea what he is doing, and you think he should be given a step by step guide? He doesn't need professional advice he needs taking out of the frame like part "P" was supposed to do.
To be honest given that the op hasn't responded for what may be for perfectly legitimate reasons and hasn't had time to expand or reply then I find it pathetic that there has been a bit of a ganging up of negative derogatory replies, I'm not going to take to task each member but I'll just set a warning out that the forum won't tolerate such abuse and if it carries on then we will be losing some of you... if you cannot help and be constructive with advice then don't post.
Oh for christ's sake Darkwood stop being so blinking dictatorial and get real. The guy obviously has not got a clue what he is doing and shouldn't be coming on here asking for such basic advice. Is this what the forum is for, assisting people to take money off the unsuspecting public when they clearly should not be at large? And do you really think the OP is going to come back??
With all respect and maybe you are right but there are a few ways of giving your opinion, A - The polite way with constructive advice or B - To mock and demoralise another member, looking at your very recent posts it seems you have little interest in A and use the forum for your own amusement, I suggest if you have had a few sherberts then you consider your response carefull, we all probably come on line after a few and spout things that can be a bit insulting, derogative and/or abrasive hence I didn't take it further.. we are not going back to the old days of members ganging up on people, there are 2ways to get a point across, if a member is clearly out of their depth then be polite and give constructive advice.
This is no longer up for discussion so please don't question it again.
Fair enough.
Reply to Rcd trips after installing rcd in the UK Electrical Forum area at ElectriciansForums.net
In my opinion replacing the consumer unit and waiting to see which RCBO trips is not a good fault finding technique. If the lighting circuit...
davesparks
Which rcd is it? Is it one for everything, one for a few circuits?
