P
petewan
Hi , I am going to spur off a ring socket circuit, connecting a rcd protected fused connection unit BS4293 to a double socket on the ring, then spur off to a double socket.
As I’m just taking a spur off a ring can I do this a minor works ?
The rcd unit is because the ring is not RCD protected, so as to conform to 17 th
Any ideas you may have would be appreciated
Thanks Pete.
Thanks Pete.
