J
Just
Hi, When I test socket ring x 1 I get 44ms and when I x 5 I get greater than 25V touch.. Zs is 0.53 and Ze is 0.17, IR is low 25M. Any ideas greatly appreciated
Discuss RCD x 5 touch voltage too high in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi thanks, I checked the manual and it just says touch voltage too high and that old chestnut 'requires further investigation' which to be fair it does! The meter which is a Socket&See was calibrated a few weeks ago. Any other circumstances would start testing but as the x 1 was 44ms surely there must be a fault with the rcd? As you say test with another. A poor IR wouldn't have anything to do with it would it?
Reply to RCD x 5 touch voltage too high in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
