B
bluecallum
Just done a eicr on a property,socket outlets on one circuit on rcd testing at 5x is 42ms,what are you meant to do as readings on 1x is within the limits.as the 5x exceed limits.
Discuss Rcd in the UK Electrical Forum area at ElectriciansForums.net
It is a 30ma Rcbo,a new consumer unit went in with 61009 RcbosIm assuming the tested rcd is rated at 30ma
Reply to Rcd in the UK Electrical Forum area at ElectriciansForums.net
