rcds | on ElectriciansForums
Discuss rcds in the The Welcome Forum area at ElectriciansForums.net
I thought I was right I just needed another view to prove I`m right, I`m having a debate with a landlord over this, as I pointed out to him that the main rcd switch failed the cut out time meaning the portakabin my client is using is not compliant with the regs and he said I`m not changing the main rcd unit install another one to the portakabin, I said you cant do that it will conflict the other rcd
You should not have 2 RCD's of the same value in series. If the main one has "failed" to test within the correct times then it should be replaced. Installing another one downstream is not a proper solution.
On rare occasions it can be prudent to have 2x RCD in series to give a measure of redundancy due to the somewhat fallible nature of the beasts.
But it would be something designed in from the start, not done as a way of getting around a failed RCD.
Reply to rcds in the The Welcome Forum area at ElectriciansForums.net
If the main DB RCBO is there to provide additional protection (as it most probably is), then no, as S type RCDs are not suitable for providing...
loz2754
L
Regulations notwithstanding, the only thing in those pics that is likely to be affected by sheep is the trailing flexibles on the ground from the...
