RCDTripping, | on ElectriciansForums
Discuss RCDTripping, in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
P
peter_k800
Hi, My RCD (B Type) in my warehouse trips every now and again and there is a small compresser and pump and a couple of washing machines along with a couple of other small bits, All on seperate circuits. Just wondering could i change the RCD to a C Type and would this sort the problem? Thanks.
Hi there
A bit confused....RCD's deal with earth fault and only come in one flavour, with varying mA ratings.
Could you clarify a bit??
Thanks, How about if i put the compresser and pump on a C type MCB without an RCD as its all surface would that be ok?
You can get domestic RCD's B Type, You can also get motor RCD's C Type
/QUOTE]
Yes
If you are a skilled or instructed person,no need for any RCD unless its TT
Depends wether the compressor is supplied via a socket or not?
But why is a compressor and pump on the same circuit?
Reply to RCDTripping, in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
If the main DB RCBO is there to provide additional protection (as it most probably is), then no, as S type RCDs are not suitable for providing...
loz2754
L
In my opinion replacing the consumer unit and waiting to see which RCBO trips is not a good fault finding technique. If the lighting circuit...
davesparks
