Re 30ma rcd main switch | on ElectriciansForums
Discuss Re 30ma rcd main switch in the Australia area at ElectriciansForums.net
hi guys first post here just wondered if any advice was available.
my consumer unit has a 63 amp 30ma RCD mainswitch fed from a 60amp TNCS supply.i intend to run a supply from one of the spare ways in the consumer unit via 20a mcb to the garage which will supply 2 lights ,one outside socket and one internal socket via 2.5mm T+E clipped through loft and then out to garage via conduit (2m) horizontal and (2.5m) in height (bungalow) to a 5way 63amp main switch garage cu and then via (16amcb) and (6amcb) to power and lighting. 2.5mm and 1.5mm singles mounted in conduit.
i have two main questions
1/ im not happy with the fact that 30ma front end rcd is covering the whole installation( garage and bungalow), but apart from either changing the consumer unit to allow for dual rcd board, or the splitting of tails and seperate garage supply i can not see any other way of providing discrimination to satisfy the regulations.
as it stands any fault currently trips all circuits within the installation
2/ taking account of the issue of discrimination would this be noted as a limitation and a recomendation for a dual rcd board be made.
many thanks ian hope someone can advise
thanks for your reply Murdoch, thats what i was considering, henlyblock too switch fuse then swa to garage rcd protection(at garage end) just seems a little over the top for two sockets and a light, but with the board limitations i cant find any other way of providing discrimination to the garage circuit. if discrimination can not be obtained then i was thinking that due to the fact that at present the whole installation is covered by the 30ma rcd main switch and the fact that it is a bungalow (no stairs,one lighting circuit,one power circuit) it may not add to the dangers or risks if the garage was to be wired from a spare way in the existing CU.
just to float this if it were to be wired from the spare way in consumer unit via the front end rcd and the risks associated with rcd tripping were minimal is there anything in the regs ( i cant find anything) that would dictate this shouldnt be done? i agree with the points made here just for future refeference really ?
thanks mark thats what i kinda thought. not best practice and not ideal to have one rcd covering all circuits due to loosing all circuits but retrospectively rcd main switches have been fitted so i guess its pretty common.
I'd "sell" the benefits of the henley block/2nd CU to the customer, but its your customer!
Just imagine next winter and little fury creatures make a home in the garage and start eating the cable, bang out goes the house - not an ideal situation!
If there's not many ways, change to a main switch and use rcbo's, although dual rcd board would prob be cheaper, I'd personally go down the splitting the tails route as the others have said, if it's for urself and you are doing the work, a dual board fully loaded only 70-100 quid
thanks for the replies much appreciated.
on a similar note if you find this arrangement ie front end rcd mainswitch at consumer unit and customer requests a new circuit be added on a spare way ie shower or cooker radial. without replacing the board or totally changing its configuration, i see no way of complying with regulation 314 ( segregation of circuits) is it therefore a case of the consumer unit beeing treated as a retrospective installation and therefore does not need to comply, or by adding a new circuit to the exisiting CU configuration mean that reg 314 has to be met. any advice would be gladly appreciated.
Reply to Re 30ma rcd main switch in the Australia area at ElectriciansForums.net
Regarding the EV, it’s an Ohme charger which I believe has a type A RCD built in, setup would be: 50A RCBO to feed garage db Garage db has no...
Seen this where T&E has been fixed with a flat bend of too tight a radius.
2 3
