Re-wire or upgrade earth bonding? | on ElectriciansForums
Discuss Re-wire or upgrade earth bonding? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
K
ketanc
Hi All
My first post so please bare with me. I am a landlord and currently refurbishing a property. I called in a local electrician to get a quote on having a kitchen extractor fitted, and he basically noted the following things:
- ALL wiring (sockets, switches, lights) in the property is two-core red and black wires. Being clueless when it comes to this, my description of it is copper wire quite thick multi strand inside red and black sleeving, which in turn is inside a white sheath.
- Water stopcock is not earth bonded
- Gas inlet pipe & consumer unit are the only two things that are earth bonded
- None of the sockets/switches/lights have any sort of earth wire running to them whatsoever
He has said I need a full re-wire of the property, with an attached price tag of course. I wanted to ask the guys on this forum if it is permissible to have an electrician come in and run earth bonding cable externally (i.e. in trunking), to and from all points in the house, all running back to the earth block below the consumer unit?
As a landlord, obviously, I will need an NICEIC approval certificate before my property can be let - will this method pass, or is it a straight up "hell no"?
If (as I suspect), it is a NO, please could I have some guide prices for a full house re-wire, so I know I'm not being taken for a mug! - it is a 3 bed semi detached. Enter another problem -- my "project manager" (if you could call him that!), has already had the house re-plastered. This was all done while I was out of the country! So chasing the wall is not an option, surface boxes and trunking is the only option!
Room details:
Entrance hall - 3x light fixtures, 1x double socket, 1x upstairs/downstairs landing light switch
Lounge - 1x ceiling rose, 3x double sockets
Lounge Cupboard - 1x light switch, 2x bulb holders
Downstairs toilet - 1x ceiling light, 1x light switch
Kitchen - 5x double sockets, 1x light switch, 1x electric oven switch, 1x boiler switch
Upstairs landing - 1x ceiling rose, 1x upstairs landing light switch
Upstairs bathroom - 1x electric shower 8.5kw, 1x electric shower pull cord switch, 1x bathroom pull cord light switch, 1x timer extractor fan
Bedroom 1 - 1x double socket, 1x light switch, 1x ceiling rose
Bedroom 2 - 2x double socket, 1x light switch, 1x ceiling rose
Bedroom 3 - 2x double socket, 1x light switch, 1x ceiling rose
My apologies for the in depth post, just thought I'd provide as much info as possible!
Thank you in advance for all replies and help received!
Kay :)
What you should do is get a full EICR done - ÂŁ150 - ÂŁ200 to get a proper picture of the situation.
This will tell you properly what is going on.
If its a rewire you need to ensure that the person/people doing the work are registered, competent and will provide an EIC and LABC notification.
There is no such thing as a NICEIC approval certificate - the NICEIC are just one of the bodies in the trade
A rewire could be ÂŁ3500 ish
PLUS you will need the plasterer back as the numpty will need to do a lot of making good - surface trunking will look really NAFF.
EDIT: And you'll need RCD protection too
Murdoch say s it well. Also look on the ESC (electrical safety council) website a there is information there specific to landlords/let properties.
As what Murdoch says, and take the money for the EICR from your "project manager" as he is a numpty...
If your happy to have trunking running everywhere you may aswell get your electrician to quote a rewire in trunking and surface boxes. I think it looks naff personally but that'll be your cheapest option by the sounds of it to make the installation more safe.
If the wiring is as you have described, you are probably looking at a complete rewire and firing your project manager. I shan't bore you with the details, but wiring is all about avoiding heat. There are different installation methods for cables, all with their own correction factors for heat. Wiring a house in plastic trunking is going to need bigger cables to reduce the resistance and therefore reduce the heating effect. If you don't trust the original advice from the electrician you had round, ask another one, I'm pretty sure they'll give you similar news. As for a price, there's a lot of factors that affect costs, mainly how long it's going to take to get under the floors, up the walls etc. get a few quotes and pick the one you find to have the best chance of getting the job done in time for your tenants to move in.
If its for a let, you may wish to check with Estate Agents re the surface trunking as I suspect it would affect your monthly rental income.
Lots to think about....
thank you for all your responses guys, I guess I have lots to think about this morning! I think the first step is an EICR, as Murdoch said.
thank you all again :) in the words of Arnie... I'll be back!
i find it hard to believe that there is no earthing on the sockets. lights , maybe, but very rare to see socket circuits without. is the wiring in steel conduit, by any chance? can you ease off a socket front ( with the supply isolated ) and see if there is a connection to the earth pin?
I would also definitely advocate having the cables plastered in the walls. If you are doing this as a refurb you need to take into account the longevity of the install.
Surface trunking lid goes missing over time, it can get prised off by kiddies if installed poorly leaving cables to tug on, surface boxes are brittle and get cracked and damaged.
All in all it's a 2nd rate job that will also look TERRIBLE.
Patching over all the chases should not take a plasterer longer than a day at the very most. The cabling in a rewire should last you 20-30 years if not longer, so make sure it has the best installation to help prolong it's life.
Hi Tec,
I have taken off two sockets and there are no earth pin connections, only red and black twin. The same is for three light fittings I've taken off.
I've had way too much bad luck lately, and frankly I (nor my wallet) can take another battering!
I was wondering this too. I have never seen anything other than lighting with no earth. I have seen redundant black rubber sheathed twin with no earth, but the OP describes it as red/black twin with white sheath. Anyone seen this before ? Only white sheath I have seen is modern LSF.
there are a few professional spark forum members in your area. no doubt 1 will be able to arrange an inspection for you if you hang around a bit.does sound like a full rewire is essential, though. how much were you quoted?
Reply to Re-wire or upgrade earth bonding? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Joining the ends of the radials together to form a ring, and changing the circuit protection to a single 32A would solve the MCB overload problem...
