K
ketanc
Hi All
My first post so please bare with me. I am a landlord and currently refurbishing a property. I called in a local electrician to get a quote on having a kitchen extractor fitted, and he basically noted the following things:
- ALL wiring (sockets, switches, lights) in the property is two-core red and black wires. Being clueless when it comes to this, my description of it is copper wire quite thick multi strand inside red and black sleeving, which in turn is inside a white sheath.
- Water stopcock is not earth bonded
- Gas inlet pipe & consumer unit are the only two things that are earth bonded
- None of the sockets/switches/lights have any sort of earth wire running to them whatsoever
He has said I need a full re-wire of the property, with an attached price tag of course. I wanted to ask the guys on this forum if it is permissible to have an electrician come in and run earth bonding cable externally (i.e. in trunking), to and from all points in the house, all running back to the earth block below the consumer unit?
As a landlord, obviously, I will need an NICEIC approval certificate before my property can be let - will this method pass, or is it a straight up "hell no"?
If (as I suspect), it is a NO, please could I have some guide prices for a full house re-wire, so I know I'm not being taken for a mug! - it is a 3 bed semi detached. Enter another problem -- my "project manager" (if you could call him that!), has already had the house re-plastered. This was all done while I was out of the country! So chasing the wall is not an option, surface boxes and trunking is the only option!
Room details:
Entrance hall - 3x light fixtures, 1x double socket, 1x upstairs/downstairs landing light switch
Lounge - 1x ceiling rose, 3x double sockets
Lounge Cupboard - 1x light switch, 2x bulb holders
Downstairs toilet - 1x ceiling light, 1x light switch
Kitchen - 5x double sockets, 1x light switch, 1x electric oven switch, 1x boiler switch
Upstairs landing - 1x ceiling rose, 1x upstairs landing light switch
Upstairs bathroom - 1x electric shower 8.5kw, 1x electric shower pull cord switch, 1x bathroom pull cord light switch, 1x timer extractor fan
Bedroom 1 - 1x double socket, 1x light switch, 1x ceiling rose
Bedroom 2 - 2x double socket, 1x light switch, 1x ceiling rose
Bedroom 3 - 2x double socket, 1x light switch, 1x ceiling rose
My apologies for the in depth post, just thought I'd provide as much info as possible!
Thank you in advance for all replies and help received!
Kay
Room details:
Kay
