The below is a PM I received the other day from a DIY member. He is an RAF Engineer and builds, repairs and maintains fighter jets and the like. He posted up on here about 2 years ago now, a small fault in his daughters house and asked for help which he got absolutely slatted for on the open forum! Since then he asks me directly for help. Do not be concerned about him "changing light fittings, switches and sockets". If he can install a wiring loom to control the launch of a missile strapped under a plane, a few wires in a socket is childs play, not your typical normal DIYer trust me lol. Really nice bloke I may add.
So there is the background info so you know the history, here is the question:-
What are your thoughts on this real world situation from an actual customer? This is his PM:-
hi paul its **** from ********. i wonder if i could ask you a question which might lead to a job for you, my son has moved into a rented house in which he is very happy. its a nice enough house and i have done a fair bit of diy electrical work for him, light fittings, replacing sockets etc. one thing i do think needs addressing is his fuse box, it is an old push in wired.cartridge type fuse box. it has four fuses feeding 1. immersion heater. 2. sockets 3. lights. 4. electric shower. the meter box is outside the front door and the fuse box inside the front door which is the kitchen no more than 6 feet from the meter box. it is situated in a cupboard underneath his sink which i dont think is a very good location. i believe it would be better fitted in the cupboard immediately above his sink a distance from the current location of about five feet vertically up. i would think that the cables are likely to need extending. i think that what is required is a suitable consumer unit with mcb/rcd. what do you think? and can you give me an approximate cost for the job rgds ****
