View the thread, titled "Real time monitoring of PV system" which is posted in Solar PV Forum | Solar Panels Forum on Electricians Forums.
Sorry, my point was that if you couldn't get a power socket into the loft you could run the cable from the inverter to the solar log through the ceiling - although ideally the solar log should be close to the inverter.
You're right you need to consider how to connect the solar log to the network either via ethernet cable or go for the slightly more expensive wifi models.
Another source of prices is here: Solar Log Monitoring
Reply to the thread, titled "Real time monitoring of PV system" which is posted in Solar PV Forum | Solar Panels Forum on Electricians Forums.
