'Real World' CU upgrade. | Page 2 | on ElectriciansForums
Discuss 'Real World' CU upgrade. in the UK Electrical Forum area at ElectriciansForums.net
Dave OCD
Mentor
Cornwall
I just thought I'd post up a typical (but smallish) CU replacement done today. Commonly you don't have much if any slack cable to work with and with trying to dress previously connected conductors you're never going to get the same level of neatness as a brand new install. But I think this is a reasonable standard. I really like the Fusebox CUs, they seem very well made and the RCBOs always test out very well. ?
[ElectriciansForums.net] 'Real World' CU upgrade.
Thank god there’s no ferrules on the 6mm conductors going into the rcbo, the YouTube gang would be furious with you Dave.
Believe it or not they are ferruled Ian, just hard to see in the picture. And to quote Jim Royle , I couldn't give a shiny sh1te about the YouTube gang. ?
Indeed, close inspection shows the uninsulated ferrules used! Neat.
Also the originals are not soldered - that is a big no-no for screw terminals as it compresses with time and becomes loose - but it is an ultrasonic weld. Basically squashed it to sold again.
Looks good. Did MK make the devices? Look a bit MK like in terms of their interpretation of vertical.
The key to overcoming the MK slant is a quick release ratchet clamp, grip the mcbs, rcds and main switch etc then fit busbars. everything then sits nice and vertical without the slant.
Reply to 'Real World' CU upgrade. in the UK Electrical Forum area at ElectriciansForums.net
