Really annoying problem! | on ElectriciansForums
Discuss Really annoying problem! in the UK Electrical Forum area at ElectriciansForums.net
D Skelton
Mentor
Nearly Esteemed
Milton Keynes
I installed this SWA a while back and ever since I have been back on a monthly basis to keep replacing the cable ties as they seem to snap all the time. What's going wrong with my install???? Maybe the wind is getting to it???? :D :D :D
[ElectriciansForums.net] Really annoying problem!
quite obvious. the plasticiser in the fence coating leaches into the pvc cable tie and causes degradation.
- - - Updated - - -
if they were spaced further apart, there'd be less to replace.
Reply to Really annoying problem! in the UK Electrical Forum area at ElectriciansForums.net
Met landlord on site as he lives not far away and showed him which filters he needed so he could see for himself. Cooker is on inside wall of a...
  • Solved
There is an article about that here: https://www.cement.org/learn/concrete-technology/durability/corrosion-of-embedded-materials It states...
