E
Earthstore
That looks quite neat, well apart from the board that is, it should really have two AC isolators though, one for each inverter.
The tripping/high voltage that has been referred to is the AC voltage, if it is quite high coming into the house IE around 250v, and the AC cable to the inverters is too small it can cause the inverter to go over voltage, it is a very common install fault.
I hope this helps.
I hope this helps.
