recall on fuse wire | on ElectriciansForums
Discuss recall on fuse wire in the Australia area at ElectriciansForums.net
Is there no such thing as R&D or routine quality checks in the electrical industry anymore ?
Electrum springs to mind !!!!:disappointed:
This firm must be run by accountants or an investment group, complete asset strippers with no common sense, probably killed off their own R+D and QA departments to scrimp a few pence off a low volume, low margin, safety critical component.
nasty nasty recycled copper with bits in it.
I know a chap that runs a nuclear fuel reprocessing plant and the steel used for parts of the process containers, HAS to be mined from scratch, they specify the mine, and it has to be a german one!
Sehr Gut
Reply to recall on fuse wire in the Australia area at ElectriciansForums.net
It can be easy to lose the sequence of things. If the fused spur has a neon indicator and this isn’t coming on then I wonder if -the original...
  • camperVanGuy101
  • Australia
  • 2
  • 738
