Hi All,
I'm a Network/Software consultant, but I also do Access Control, and consult on basically anything else electrical! Run into a fun one at a clients, they have a 3-phase roller shutter which seems to be controlled (having had a peek into the box) by a pair of contactors with an overload between them. As near as I can tell, the motor is doing it's own limit stuff (there appears to be a limit switch in the wiring, but it's hanging to one side with the switch taped closed!) but they're not able to secure the unit from being operated that easily as it's just contactors. They'd also like to be able to tag the net2 and control the door from outside (which doesn't have a rear door, and it's a bit of a trek round the back!). I've seen various roller shutter controllers on eBlag, but none are three phase, and my usual friendly sparks has never installed anything like that, so can't reccomend one.
Has anyone had the pleasure? Client's a cheapskate (aren't they all?) so is after a cheap solution to the problem. I know these things exist, just haven't a scooby doo as to where to look, and most roller shutter companies want a service contract and half an arm and the full leg to install one as none of them are based locally (and all the local ones CBA to quote me!).
Any help would be appreciated!
Cheers
Alex.
Cheers
Alex.
