Recess led light in limited space | Page 2 | on ElectriciansForums
Discuss Recess led light in limited space in the UK Electrical Forum area at ElectriciansForums.net
cliffed
Worcester
i know this is a regular occurrence,the fitting of recess lights in limited space & with celotex being fitted.why is it always the sparkles problem,when you've got designers specificing the fittings.
We've got about 100 mm from bottom of joist to ceiling,to be fair the builders have cut out the celotex around where the fitting will go,it's at 1st fix stage now.
It's now up to us,to find a suitable fitting,they will have to be integral drivers,to the fittings,any ideas,if this will be possible,.
Reply to Recess led light in limited space in the UK Electrical Forum area at ElectriciansForums.net
