Recessed downlights on a dimmer switch | on ElectriciansForums
Discuss Recessed downlights on a dimmer switch in the UK Electrical Forum area at ElectriciansForums.net
N
northie100
I wonder is anyone can help with this ...
I have a bank 6 downlights in my ceiling (installed about 10 years ago), with a double dimmer controlling 3 each.
Gradually the spots have decided to not function, so that now only 1 on each bank of 3 works.. so to me that rules out a dimmer issue ..
As a potential solution I have just fitted new transformers (there is one each) and I can hear then working, however ... I am also installing new downlighter fittings as well and these don't work ... ie: I have power to the transformer and I can hear it buzzing, but if I take off one of the remaining working spot fittings and replace it with a new one, it doesn't work! If I put the old one back on it does ... it's just 2 wires ....? As for the others, the situation is the same with the transformers buzzing ...
The only difference I can think of is that the new spots use GU10 but the old fittings used the bulbs with 2 spikes ... but were still in the same wattage range (30-50W).
I am guessing I am missing something very obvious here, but it makes no sense to me.
Hope someone can suggest something
Wish it was wind up ... I really am that dim lol
If you really are that dim, then the only course of action recommended is to get an electrician in to sort them out for you.
It would be foolish to mess with wires with zappy juice in them if you had to ask the first question.
I'm pretty sure it's a wind up too though.
Reply to Recessed downlights on a dimmer switch in the UK Electrical Forum area at ElectriciansForums.net
Yes one wire nut will grab a wire but I will suggest an orange one because the wire is 14 gage wire for lighting.
I'd start by doing the usual supply impedance tests followed by N-E voltage with the installation under some load. Also visually inspect and...
