Recessed downlights on a dimmer switch | Page 2 | on ElectriciansForums
Discuss Recessed downlights on a dimmer switch in the UK Electrical Forum area at ElectriciansForums.net
N
northie100
I wonder is anyone can help with this ...
I have a bank 6 downlights in my ceiling (installed about 10 years ago), with a double dimmer controlling 3 each.
Gradually the spots have decided to not function, so that now only 1 on each bank of 3 works.. so to me that rules out a dimmer issue ..
As a potential solution I have just fitted new transformers (there is one each) and I can hear then working, however ... I am also installing new downlighter fittings as well and these don't work ... ie: I have power to the transformer and I can hear it buzzing, but if I take off one of the remaining working spot fittings and replace it with a new one, it doesn't work! If I put the old one back on it does ... it's just 2 wires ....? As for the others, the situation is the same with the transformers buzzing ...
The only difference I can think of is that the new spots use GU10 but the old fittings used the bulbs with 2 spikes ... but were still in the same wattage range (30-50W).
I am guessing I am missing something very obvious here, but it makes no sense to me.
Hope someone can suggest something
I repeat what I said earlier - no wind up. An honest question, to which my first reply gave me the answer ... I have enjoyed the banter you guys have had today, but let's not be condescending ... the only reason I registered was because I needed the answer, no shame there. Thanks for letting me in and helping me out. :smile:
oh, sorry :(
Definitely no shame in asking :) hope the issue gets sorted!!
I thought you were one of these guys having a wind up...it happens daily.
So now you can tell us about your bits :)
Reply to Recessed downlights on a dimmer switch in the UK Electrical Forum area at ElectriciansForums.net
Yes one wire nut will grab a wire but I will suggest an orange one because the wire is 14 gage wire for lighting.
I'd start by doing the usual supply impedance tests followed by N-E voltage with the installation under some load. Also visually inspect and...
