recessed downlights.... | on ElectriciansForums
Discuss recessed downlights.... in the Australia area at ElectriciansForums.net
sythai
Devon, United Kingdom
Hi Chaps....
This one is for anyone that prices by point.
Just want see how I compare and what others are charging per down light.
I charge ÂŁ38/per standard GU10 fitting any finish non IP - regardless of how many.
Many Thanks,
Sy
Nop that's all on top if required....
Also based on it being a plasterboard ceiling - new build or fully occupied house with chipboard floors same price.
Doesn't included patching or re skimming ceiling if required (no access from above - tiled floor etc) or getting carpet back down perfectly
depends what price youre getting the downlights for (if youre supplying them that is)
but at that price an average room of 8 at around ÂŁ300 not incudng any other work which wth bonding and rcd protection would prbably make a bill of around ÂŁ500 for a days work, customer will only see the cost of materials (and thats just the basics)
ÂŁ3.50 a fitting ÂŁ1 a jnction box and a 35p a mter of cable, bulb ÂŁ1 each talking ÂŁ60 for materials max so ÂŁ240 for a days work sounds good to me but it probably take me two days. and still sounds good
Where are you getting fire rated downlighters from for ÂŁ3.50 and can you get me some?
your living in a dream world !
try this and you might actually comply with regs.
FR downlight, im getting them for ÂŁ6.35 with the vat
3 wagos ÂŁ0.60
1 wago/ choc box ÂŁ1-1.75 ish
3mtrs cable per fitting which allows for supply runs, ÂŁ1.20-1.75
decent lamp as customer will go radio if the cheap ÂŁ1 bulb blows in a fortnight ÂŁ2
and if its LV then ÂŁ4.50 for a tranny
only have to be fire rated if theres insulation above, most say long as 100mm clearance all angles, ÂŁ3.50 normal robus foittings is good to go? maybe im wrong hightower, but manufactures instructions over rules all
Do you think its a good idea to discuss such costings in the open forum? Maybe best in the Arms.
To be fair I have tried that before but takes a little too long to get a response if any.... :sad_smile: Nothing to hide with my pricing it's all clear and transparent to my customers :smiley2:
Oh well it was worth a try posting, was doubtful I would get a simple answer of ÂŁxx/ per fitting. Maybe I was being a little vague with my inital post..... nevermind.
Thanks anyway Sy
Where's the idea of 'only has to be fire rated if there is insulation above' come from?
the old myth. the fact is that fire rated fittings are to preserve fire barriers. it don't make anything fire proof. fire rated fittings are only demanded when the above floor is separate occupancy or a dwelling room/s above a garage etc.
Reply to recessed downlights.... in the Australia area at ElectriciansForums.net
seen a couple of your posts now and IMO you are trying to save money by doing the design and install yourself even though you have no...
OVIA IBEX 5W EMERGENCY LED SELF-TEST NON-MAINTAINED DOWNLIGHT
