recessed downlights.... | Page 2 | on ElectriciansForums
Discuss recessed downlights.... in the Australia area at ElectriciansForums.net
sythai
Devon, United Kingdom
Hi Chaps....
This one is for anyone that prices by point.
Just want see how I compare and what others are charging per down light.
I charge ÂŁ38/per standard GU10 fitting any finish non IP - regardless of how many.
Many Thanks,
Sy
ÂŁ3.50 a fitting ÂŁ1 a jnction box and a 35p a mter of cable, bulb ÂŁ1 each talking ÂŁ60 for materials max so ÂŁ240 for a days work sounds good to me but it probably take me two days. and still sounds good
why 2 days for some downlights?....plot your joists (to avoid em)..cable, rods..etc....2 days????
the last time and first time i done them. i marked out all joists and marked all places where wanted lights to go but as i progressed there was double joists and joist crossing for extra support so the few hours i spent marking out was a waste a time. id say next time or time after i will get all done in a day if i cot say 100mm track out all way round room, and i used junction boxes with heat resistant flex off too lights, was very time consumin if i dont say doing it yourself
The last 2 i did, i was able to get above and drill either side of joists at each end of the room. Chalk lined it all out so could see joist positions. Took a bit of time to set them out but didn't run into cutting into joists
you want an apprentice next year glen spark when ive level 3 done before telectrix snaps me up like a sausage roll;)
Why didn`t you go on the apprentice framework from day one?...I am on level 2 year 2 so have the NVQ this year......but the point i was trying to get across was 2 days for some downlights seems a bit exessive.....what do you think?
2 days seems very excessive!! how many you fitting 100???
i fitted 10 once in a customer lean to extension with no access from above and no idea where joists where!! took 3/4 of a day between 2 of us..!
Reply to recessed downlights.... in the Australia area at ElectriciansForums.net
seen a couple of your posts now and IMO you are trying to save money by doing the design and install yourself even though you have no...
OVIA IBEX 5W EMERGENCY LED SELF-TEST NON-MAINTAINED DOWNLIGHT
