P
Discuss Recessed Lighting Bulb Change in the Lighting Forum area at ElectriciansForums.net
Make sure the light is turned off when you change it as they get very hot very quicky , also make sure you get the correct bulb, take your old one with you to the shop, if its the bulb with to thin pins then it will be 12 volt,Aah, I didn't realise it was that simple!
I've removed the bulb and I'll buy a replacement and see whether it works.
Thanks all!
Reply to Recessed Lighting Bulb Change in the Lighting Forum area at ElectriciansForums.net
