Recessed Lighting Bulb Change | Page 2 | on ElectriciansForums
Discuss Recessed Lighting Bulb Change in the Lighting Forum area at ElectriciansForums.net
I've attached a picture of a recessed ceiling light.
I can't get the fitting out of the ceiling to change the bulb.
Does anyone have any tips?
Thanks in advance for any help.
Phil
If you need to change a recessed light bulb, the first thing you'll need to do is locate the fitting. Once you've found the fitting, gently twist it counterclockwise until it comes loose from the ceiling. Then, simply pull the fitting out of the socket and change the bulb. Be sure to dispose of the old bulb properly.
he said it was the switch. the new one's probably failed as well by now, 5 years down the line.
Reply to Recessed Lighting Bulb Change in the Lighting Forum area at ElectriciansForums.net
Hope everyone has had a great Christmas and here’s hoping we all have a better new year coming our way ! Remember our riches aren’t measured by...
Ha.had a whole school corridor like that when I was an apprentice ,was only changing type of fitting .nightmare .couldn't work out why there was...
Hi Brian , So true, Got millions of those lying around too...as A driver maker i look at all faults i see, I guess its part of the job... thanks
