Rechargeable wrk light for when changing DBs etc | on ElectriciansForums
Discuss Rechargeable wrk light for when changing DBs etc in the Electrical Tools and Products area at ElectriciansForums.net
B
brizospark
Looking for a good rechargeable work light that will be good for when changing DBs in dark cupboards and the like!
anyone got any suggestions?
Petzl Head torch. Always points in the right direction and doesn't cast shadows like a work light. Plus the batteries last for even on low setting which is all I normally use.
i generally just fumble around in the dark. chance is i'll get a few cables in the right holes-- enough to get some light-- then with some power on, fix all the wrong ones. :gunsmilie:
and if you get them in the wrong holes then they will light up all on their own :lol:
Last cu change I did was in a dingy under stairs jobby, and was dark down there so I used an emergency light that I was throwing in with the change as if the board tripped in the future on the downstairs lighting they could see what they were doing down there....I put it on a plug the night before to charge it up for the change.
Which model do you recommend? I'm on the look out for a new one that will also fit round my hard hat if needed
Sent from my iPhone using Tapatalk
I use a Petzl Tikka. Simple 2 brightness LED with two brightness settings which I always use on low as I don't find I need a bright light for the stuff I do (domestic). I am not sure if it would fit a hard hat and if you use one of those I guess you are working on building sites or industrial so you might want a more powerful one?
Reply to Rechargeable wrk light for when changing DBs etc in the Electrical Tools and Products area at ElectriciansForums.net
My guess is an earth to N fault in the damaged light fitting. This will become a problem when other devices draw large currents.
The problem is not GMT (UTC) or BST (DST) it is the not knowing what the times are, I was told to start with midnight to 8 am, then sorry no it's...
