Recommend dimmable constant voltage driver for a LED strip | on ElectriciansForums
Discuss Recommend dimmable constant voltage driver for a LED strip in the Electrical Tools and Products area at ElectriciansForums.net
Grayza
Woking
Hi, can anyone recommend a dimmable constant voltage driver for a LED strip and any suppliers?
Many thanks
Depends tape rating (w/m) but there are many about. Also depends on dimmer type being used (eg 239v 0-10v etc etc)
Teucer are generally quite reliable.
I'd recommend Meanwell drivers. Well designed and well built. I've installed hundreds over several years and very few failures.
Reply to Recommend dimmable constant voltage driver for a LED strip in the Electrical Tools and Products area at ElectriciansForums.net
Thank you so much for your help I appreciate it alot. I learnt alot and saved alot of money in the progress kudos. Best wishes to you too.:bowing:
Hello. This is such a noob question, but I'm struggling with something that seems like it should be fairly straightforward. I have numerous 24v...
