Recommendations for LED Floodlight for garage and garden | Page 2 | on ElectriciansForums
Discuss Recommendations for LED Floodlight for garage and garden in the UK Electrical Forum area at ElectriciansForums.net
North Wales
Hi All,
I will be having a full rewire done shortly and will fit an LED floodlight for the garage and driveway, and one for our garden. My budget is £35 per light (or thereabouts).
So far, 2 manufacturers have come up in my research: Timeguard (Timeguard LEDPRO10B 10 Watt Black Professional LED Floodlight - Edwardes - https://www.edwardes.co.uk/en/products/timeguard-ledpro10b-10-watt-black-professional-led-floodlight) and Deltech (10W Slim LED Flood Light 6250K with PIR - Black | QVS Direct - http://www.qvsdirect.com/10w-slim-led-flood-light-6250k-with-pir-black).
Both are 10watts (although I know this doesn't matter so much), and IP65. The timeguard is 5000 kelvin, and Deltech 6250 Kelvin. The Deltech has 800 lumens vs. Timeguards 650 minimum lumens.
Are both reliable manufacturers, and which is the 'best' (i.e. more likely to stand the test of time)
Will the lumens stated be sufficient as security lights?
Thanks!
Thanks for this recommendation. I just brought the 10w and 30w lights. Seem good value for money, hopefully they will last.
They should. We have fitted 1000's of Ansell products and rate them highly. Their Orbio downlights would be worth looking at too if you plan on fitting downlights. If you shop around you'll get them for a little over £15 each and if you register them you'll get a 7 year warranty.
Reply to Recommendations for LED Floodlight for garage and garden in the UK Electrical Forum area at ElectriciansForums.net
My bafflement increases. I swapped the offending light with one elsewhere on the back of the house - one of those that's on a circuit of its own...
