Recommendations for Loop Tester Non Tripping | on ElectriciansForums
Discuss Recommendations for Loop Tester Non Tripping in the Electrical Tools and Products area at ElectriciansForums.net
G
Guest 004
Hi group.
Can anybody give recommendations of a earth loop tester that is non tripping of RCBO's
I have an Kewtec KT42 which is ok for for RCD's, but it will trip RCBO's. So I am looking to upgrade to maybe a KT45, but I am not convinced that it will be adequate.
Thanks in Advance
Lennytheloon posted something on this back in January.If you go back thru the pages you'll find it.Something to do with a D-lok on your meter.Hope this helps:D
no a link to the discussion on here
I just want peoples opinions on the test equipment they use as regards toNOT tripping RCBO's, I do not need any technical data. With the 17th edition now everything is going on to RCBO's, which makes testing a pain in te arse, and a heck lot longer to undertake. So I need a tester that will NOT trip RCBO's. Although manufactuers 'claim' that there meter will not trip, there is nothing written down to support this, and indeed in practice they tend to trip them.
i use a yamaha dt1794rgg4961337 seems to wirk fine, though i have to be wearing my special t shirt and my lucky boots when i do it
enigma you may find that a lot of people are useing Multi function testers Megger seems to be the most popular and that has a non trip funtion on it that wont trip rcbos
Reply to Recommendations for Loop Tester Non Tripping in the Electrical Tools and Products area at ElectriciansForums.net
I have the Kewtech that I bought in an emergency when my trusty Fluke that lasted many years gave up. It works! It has single pole testing too btw...
It was >999 on all, tested cables connected and individually, he ce the reason i came on here to ask for ideas
