Recommendations for multi tool blade for brick/plaster | on ElectriciansForums
Discuss Recommendations for multi tool blade for brick/plaster in the UK Electrical Forum area at ElectriciansForums.net
Gavin John Hyde
Patron
Somerset
I am looking for recommendations for a decent multi tool blade to cut through plaster and some brick/block. I could use a standard blade but it will kill the blade.
Have a job coming up where it needs some delicate cutting without going too heavy on the wall. normal chasing isnt an option. likewise disc cutters would be too intense and heavy handed.
I used to use decent erbaur ones, but they are no longer available.
What makes/blades are people using ?
I will be making a series of cuts to make a narrow chase and then sink a shallow box in for a switch. the chase will be less than half an inch wide, the customer has agreed to this so that it avoids too much remedial work.
Gavin Hi, can't see the point, there will be a scar on the wall 1/2" or 2" it's still a scar and will need some redecoration, just saying.
I have found cutting breeze blocks easy, the brick i need to cut is soft, its bath stone. the old erbauer blades i used i found worked fine, they were only ÂŁ8 each and as long as you didnt push it too hard into the cut and let it skim over the cutting line it worked fine without putting too much pressure on the motor. Sadly erbauer no longer make the blades and i have run out..
Are these the jobbies you are on about?
https://www.google.co.uk/search?q=e...x-b&gfe_rd=cr&dcr=0&ei=B-xoWsPfDYHS8AfV9qboCg
@FatAlan disc cutter is a no go in the old house. also cant risk a over run along an edge as the bare wall will be on display and seen afterwards, also too much dust, by using a multi cutter i can cut perfectly sized square hole and then using a mallet and chisel knock centre out. The house is immaculate to the extreme and listed, there is a old giant wheel in the downstairs fireplace that the rich folk would have put a dog in during Georgian times to spin the wheel for the spit roast! they showed me a pile of letters from building control covering a lot of it, there are so many listed things in this house, the wheel is one, there are also hooks, most of the plaster work and some bells, the entire staircase as it was handcrafted by some famous chippy! the garden is also protected as it was designed by some notable person! part of living in a unesco protected heritage city full of old buildings. At least the noise will make there pedigree cat run a mile and leave me alone, its better fed than most people is their cat.
Reply to Recommendations for multi tool blade for brick/plaster in the UK Electrical Forum area at ElectriciansForums.net
