Recommendations for surface mounted garden lights | on ElectriciansForums
Discuss Recommendations for surface mounted garden lights in the UK Electrical Forum area at ElectriciansForums.net
Gringoking88
London
Hi all,
Hope you are all well and all is good!
Can anyone recommend a nice looking garden light that can be surface mounted with side or bottom entry, e.g. can be retro fitted with surface mounted cabling?
Thanks in advance,
Martin
Do you mean a wall mounted light as in surface mounted? If so there are loads of decorative options out there from brands like Collingwood, aurora etc depending on budget
Not really as you would compromise the IP rating. These are outside on a garden wall.
You've got to have a hole somewhere.
Depending on the design of the light, one at the bottom might be the easiest way to avoid water ingress....
[ElectriciansForums.net] Recommendations for surface mounted garden lights
Reply to Recommendations for surface mounted garden lights in the UK Electrical Forum area at ElectriciansForums.net
It's unlikely tht a small domestic garden pump and a single lamp will come anywhere near close to overloading even the smallest (3A) fused spur...
What is the distance from the point outside the house to the shed?
