OP
SirKit Breaker
I did one a few years ago for Pye Hastings of Caravan (yes - still going). 6mm SWA from house, industrial combined class surge protection unit (absolutely essential), then standard 32A ring and 6A lighting circuits from a garage CU. Only problem was the dimmer for the CFL spotlights which started buzzing in B flat. Replaced that with a switch and everything has been fine since. As far as I know, the audio earth is well isolated from the mains earthing on good kit so no exceptional earthing measures are required. If it's good enough for a man with gold discs on his wall, it's probably good enough for your mate.
Cheers
Chris
You cant beat keeping it simple, nice one.
Cheers..........Howard
