Ref Part L2 (B) Lumens per watt when only Candelas stated! | on ElectriciansForums
Discuss Ref Part L2 (B) Lumens per watt when only Candelas stated! in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi,
Not sure about lumens to watts but I can tell you the calculation for lux levels on a work surface for eg.
Formula: E(lux) = I(candela) / d(distance)squared
So, if you have a lamp of 3000 candela 3 metres above a work bench, the lux level on the bench would be
3000 / 3squared = 333.33 lux
Hope this helps
Reply to Ref Part L2 (B) Lumens per watt when only Candelas stated! in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
On a small generator I wouldn't want to risk using diversity as they are not quite as forgiving as a mains supply and can very quickly fail when...
Spot on The Requirements of sections 1-6 must be complied with in a special location unless its otherwise stated in that part of section 7 that a...
