B
bluecallum
Hi can someone please let me know how the electric is pushed back to the grid,or is it stored in the export meter for meter reader to calculate reimbursment thats due,Thanks
Discuss ref pv export meter in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
the inverter steps up the voltage to push back into the house if needed if not flows out into the grid
Blimey, it' like 2010 in here.
Anyhoo, as any MCS installer worth his salt knows, the electric flows out under gravity. That's why the panels are mounted on the roof - highest point see.
JulianC, your theory can not work if the supply is overhead as the pole may be higher than the panels, or it may be a bungalow, must be magic.....
Reply to ref pv export meter in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
