That's why we introduce a high volt drop between inverter and meter point. Ideally the inverter should be as high as possible (that's why they are best put in the loft). The higher the volts can drop, the more chance they have of bouncing back up the pole. :rockon2:
oh arse. I've been attaching them to a pole on top of the chimney pot, I assumed that was why they were outdoor rated.That's why we introduce a high volt drop between inverter and meter point. Ideally the inverter should be as high as possible (that's why they are best put in the loft). The higher the volts can drop, the more chance they have of bouncing back up the pole. :rockon2:
