Hi all,
I'm not an electrician, just like to understand things for self learning. I was reading about how reference methods will derate the cable. However, either I have some misinformation or I am not fully understanding.
Given the example of twin and earth, inside plastic conduit, buried in a non-insulating wall would be method B? It is derated due to the cable being unable to dissipate heat from to being inside the wall?
If we had twin and earth clipped direct, as the cable is exposed to free air it can dissipate heat therefore method C?
Where the confusion comes is that I am reading that if it was clipped direct but then covered in plaster it would still be classed as method C? That doesn't make sense to me as now we have a scenario more comparable to the inside the wall, it should be classed as method B?
Many thanks
Many thanks
