Dave 85
What reference method would you guys put for standard house wiring (T&E through loft/underfloor/chased in walls behind capping)
Cheers Des, very helpful
Forgive my ignorance but what is the 100's club? Is it like club 18-30 but for (very old) pensioners?
The first half of the above question is serious btw
As others say, if you have more than one install method along a circuit always go with the one with the lowest current-carrying-capacity for the cable you're using.
Yes I did, cheers dude, in hindsight I don't even know why I asked the question having thought about it, it obvious, so am I right in thinking the R1+R2 result should be the same as R1 end to end plus R2 end to end divided by 4?
Also would I put 101/102 etc on the cert as opposed to A B or C for a cable in insulation?
