Refurbishment. Help needed with spooky ancient meters. | on ElectriciansForums
Discuss Refurbishment. Help needed with spooky ancient meters. in the UK Electrical Forum area at ElectriciansForums.net
jaintiler
nottingham
Hello. We are doing a refurb for an elderly lady and her family. Its a Victorian house. the local network has said it will upgrade fuse to 80A or 100A depending on capacity etc. she needs more power due to electric showers, stair lift, and our electrician will upgrade tails. But there is a mystery.
She has two meters. both old analogue ones with the rotating discs. they look ancient. one does not move at all. the other has a rotating disc moving at same speed. regardless of what is turned on etc. and the dials are stuck also. the disc just moves at same speed. Our electrician says both meters are live.
she has been paying a direct debit for years and nobody has come to check meters for years.
she has had 5 certified electricians do work on the house over the last 15 years. rewiring, new consumer board, two kitchen companies with their electricians have all done work near the meter board. Nobody has mentioned anything. she also told us that the DNO sorted the cut out as it was leaking bitumen and came out and sorted that out for her a few years ago. any idea what is happening?
if the meter is faulty the supplier should come and exchange but they cant do anything for months and we do not want to leave her with upgraded tails from a meter which clearly isnt functioning. is it normal for these old meters to do this? can our electrician change the meter and then inform supplier?
any suggestions would be helpful.
Welcome to the forum mate.
As far as I'm aware, only the DNO can replace the meter.
What have they said about the situation?
thanks for the reply. well the DNO came three years ago and sorted the cut out leak. Our electrician said he could change the meter and inform the supplier but according to you, the DNO can only do it. What is odd is that apparently these meters have been faulty for some time. do you know why there would be two meters? and also the disc on one rotating at the same speed regardless of consumption? is that normal. its a old Landis meter.
Can you post a picture of the arrangement? Showing both meters in same picture and fuse box if possible.
As well as a good photo, can you time how long it takes for the disk to rotate once (or X times if going too fast to time easily)? It might give us an idea of what load the meter has (or thinks it has).
In theory you do legally have the right to supply your own meter, but I'm not aware of anyone ever actually trying to go down this route.
I think you would find it turns out to be an absolute pain down the line.
This may have been an economy 7 arrangement the two meters being for the different tariffs. Sometimes these are overridden when the tariff changes. Looking at the electricity bill showing energy usage should give a lot more info i.e. tariff and whether the meter is actually working and which meter is in use as it should have the meter number. As to changing it, no you can't it is the property of the energy supplier whoever that is, refer to the bill for that info. It is not within the remit of any electrician or the DNO to tamper, change or otherwise interfere with the meters. Although it does happen i should not. Check the bills bottom line.
You also need the meter rev/kWh figure which should be on the front of the meter.
From memory current in A = 3600 (no of seconds in an hour) divided by voltage X rev/kWh X time in seconds for one rev.
There is usually a black mark on the edge of the disk which you use to time it. Modern meters have flashes/kWh and you time the period between the LED flashing.
I think thats right.
One of the meters is most likely Off peak and if she has no use e.g Storage heaters or Off peak water then it can be removed by the Energy supplier.
Any competent electrican would be able to work out exactly what the setup is with the meters whether they are "Spooky and ancient" or not.
If the meter is faulty the Energy supplier should attend within days not months , if they say they can't, get the customer to contact OFGEM and complain.
If the supplier won't come out for months then they have no claim to loss of revenue from the faulty meter/s.
The Electrician will need the Energy supplier to cut the meter seals and reconnect the new tails.
[ElectriciansForums.net] Refurbishment. Help needed with spooky ancient meters.
thank you. the fuse box photo is from the DNO who did the fuse work 2 years ago when there was a leak. according the lady here, they promised to come out and sort the whole box but never came back. We are not sure if the fuse head is good enough as it is to take a 100A fuse?
The old meters varied in terms of revolutions per kWh so dont think the number of revolutions at any one time will prove much.
It should however increase with loading so if at a constant speed regardless of load, can only think it is an internal fault that should be reported to the electricity supplier!
Clearly a 3 phase head which might account for the other single phase meter, although only one fuse carrier would indicate that if it is live it must be off the same phase so probably 'Off Peak' meter prior to a 'teleswitch' that has previously been removed!
Reply to Refurbishment. Help needed with spooky ancient meters. in the UK Electrical Forum area at ElectriciansForums.net
Yet another update: I believe what EDF have done is moved me from an Economy 9 to an Economy 7. I've just emailed them to ask if they can switch...
How did it go?
