regs for eicr codes | Page 2 | on ElectriciansForums
Discuss regs for eicr codes in the UK Electrical Forum area at ElectriciansForums.net
G
glasgospark
anyone know regulation number for
no grommets in metal back boxes & C3 522.8.1 ??
no flying leads to metal back boxes ? C2
I would agree with 522.8.1 but would rarely code it, just an observation.
For flying leads the back box is deemed an exposed conductive part so 411.4.2, code conditional on lug type.
GN8 says this:
[ElectriciansForums.net] regs for eicr codes
But should you code it Richard fit having no grommets. You should shouldn't you Richard .???
And most sockets now have a fixed and adjustable lug. Maybe they'll bring out new book .
If there are no grommets then as Archy says above if there is no sign of damage to the cables and they are not strained against a metal sharp edge then no code, but an observation. If the cable sheath (or insulation) is damaged (C2) or the movement of the cables could readily cause damage (C3).
The codes are there for items that may cause danger; if there is no danger (on a reasonable risk assessment) then no code.
Reply to regs for eicr codes in the UK Electrical Forum area at ElectriciansForums.net
True. Although I'd hazard a guess that things like woodworm treatment are probably chemically quite similar? Don't know.
It was purely an off the top of my head example, but I'd say - accessible live parts C1 - inaccessible live parts C2 - 10 feet up in a locked room...
Recommended Sponsor News
Hi everyone,
