J
Jabbajaws
Are kitchens considered to be a special location?
I have been led to believe by tutors that they are because it is considered a location where water can come into contact with electricity. (sink, automatic washer, dish washer)
If they are, l cannot see where this is documented in the regs.
Can anyone lend their guiding hand, to point out where l may find this out in the good old red book of knowledge please? ;)
Thanks...
Not in Bs 7671.....all special locations are in section 7 and they do not include kitchens.
Confusion comes from kitchens being included in part P,but despite being notifyable there are no special requirements.
Only addition i can make is that any work carried out in a kitchen is notifiable under Part P
Even though its a "special location" does it become notifiable if it is a like for like replacement or replacing a damaged cable ?
Replacement like for like, repair and maintenance jobs are generally not notifiable even if carried out in a kitchen or special location or associated with a special location.
Quote from building regs page 22
Hope that helps
Chris
Thanks for that Chris very helpful indeed and the last question of the day is this....
If I was to rip out a kitchen replace like for like appliances new socket fronts and light fittings without touching the wiring, unless damaged, it falls under non-notifiable?
Ideally whilst the rip out is being done its a good opportunity to upgrade but for tight arse customers who don't want to go that extra mile and the wiring tests ok.
Yep, as log as non of the sockets are relocated, you are permitted to swap the fronts like for like, then it is non notifiable.
I believe you can also renew damaged cables if they are routed the same
Someone could find and re new many damaged cables in a kitchen without needing to notify that work had been done
Its a special location all right,but not special in the eyes of an electrican working to Iee regs
It is a building reg,so the work has to comply with those regs
Considering that BS 7671 is not a statutory document and the Building Regs are you would think that kitchens would be a special location in BS 7671:rolleyes: but then why are we not suprised.
Chris
I think that the building reg's follow BS7671 and that a kitchen is not a 'special location'
It's just that a kitchen falls under the scope of part p in the same way that a 'special location' does.
It is rather odd that with bringing out the new regs, they have not included kitchens in section 7 of BS 7671, when it is clearly, l would say a concern.
I have seen many a time, sockets that have been placed directly underneath sinks, with no IP Code protection against water.
I have also seen a kitchen radial, from a 30A 3036 fuse. The radial is wired in 2.5mm sq twin&earth pvc, which feeds a tumble dryer and a washer on the same circuit. Whoever put it there obviously didnt put too much thought into this.
I know theses two appliances are protected byeir plug top fuses, but im sure that a 2.5mm sq can only handle about 20A before starting to melt. Am l correct in thinking that?
How would l go about suggesting this to IET for the next set of Regs. Are the IET open to suggestions from serving electricians? Or is it a case of some overpaid boffins in a room, who have never wired a plug in their life?
Regs & kitchens
Jabbajaws,
drywax,
TrueNAS JBOD Storage Server
