R
rob121
Just browsing through my NIC application pack and came across a leaflet regarding instrument accuracy. It taks about having to have the meter formally calibrated preferably by a UKAS accredited company etc, but also goes on to say that they must have more frequent checks by designated socket outlet, check box etc.
I only had my tester calibrated in June, so does that mean I have to go and buy a check box or is this just referring to using a check box and having it formally calibrated every 2 years?
It also says about checking the efl on a designated socket in the contractors office. Well if your on a TT system surely this is going to change according to time of year (ground being wet/dry) or if your on a TN system surely the readings change over time?
Anyway just thought I would check seen as my assessment will be coming up shortly. Seen as it only says FREQUENTLY and not a specific amount of time I might just tell him im doing it quarterly using a friends checkbox.
Cheers
Rob
Cheers
Rob
