Regulations for Mains Wiring | Page 4 | on ElectriciansForums
Discuss Regulations for Mains Wiring in the UK Electrical Forum area at ElectriciansForums.net
Lisburn
Hi,
I’m hoping someone can signpost me to any regulations that exist for installation of mains wiring cable in a domestic setting. An electrician has installed a mains cable within 30mm of wall surface in almost the centre of a wall and I’m wondering if there are regulations against this installation as i’m concerned that about the safety of this work.
Many thanks
Marty
  • [ElectriciansForums.net] Regulations for Mains Wiring
And there’s more to the story. I drilled a hole for a mirror, drilling into the mains cable(black in pic). What followed was a shower of sparks and complete power cut to home
mirror mirror on the wall who is idiot of them all ,bang me.lol.
When considering if where you want to drill is in a 'safe one', always consider BOTH sides of the wall.
I agree. Although technically, safe zones on the reverse side of a wall with an accessory on the other side, only apply in walls of up to 100mm in thickness. This is probably an outside wall with a much greater thickness.
Always use a wall scanner if in doubt.
The only unlikely scenario that the cable might be ok in the wall like that is if it’s RCD protected.
It the entire installation was TT is there a chance that this (stupidly) complies?
A photo of the main fuse / meter area would complete the set!
Looks like #11 was spot on.
It needs repaired or replaced, and in the meantime, made safe.
you’ve drilled right through the armour into a conductor, so if it didn’t blow the end of the drill bit, you’ve been lucky.
It may have drilled out some of the copper conductor, reducing its cross section area and reducing its current carrying capacity.
100A main fuse, so I think you have all electric cooking and heating? Big load to run through a damaged cable.
Reply to Regulations for Mains Wiring in the UK Electrical Forum area at ElectriciansForums.net
An example of the long term race to the bottom of quality of work in our industry, IMHO.
Thanks for your advice bud, I actually spoke to a Gold Card holder over the weekend of whom gave me the same advice
