I am trying to understand how a relay system works and have designed a circuit and a ladder diagram all as attached for an 8 PIN relay, a current sensor and a delay off timer relay. It is the sort of thing one might use with work shop power tools for automatic switch on and delayed off for a chip extractor with a manual override to run the extractor independently of the power tools operation.
In essence the chip extractor will run when a power tool is switched on, The dust extractor will run until the power tool is switch off but with say a 10 second delay (dust extractor runs on for 10 seconds after power tool switched off). There should be an override button to allow the chip extractor to be run independently of the power tools together with an off button to stop the override. Indicator lights to show whether the system is in Auto (delayed Time off mode) - Blue light, Override Mode - Green light or Off Mode - Red Light.
The normal state of the system should be off and showing a steady red light. When a power tool is being used the system should show a Blue light (Auto mode) whilst the delayed stop timer relay is activated and a Green light when the system is operating in override mode.
The components are:
The dust extractor is powered from a single 13 amp socket outlet running through the change over relay rated at 10amps. The power tools are powered from 3 x 2 gang 13amp socket outlets.
I think my logic of how the circuitry works is generally correct, however the one problem I am having is to understand how I can wire the system so that the override light is off when socket outlet no. 4 is being powered when the timer relay has been triggered and is controlling the power to the socket outlet. Perhaps I need an 11 PIN relay. I tried designing it with a DPST NO relay but this didn't give me the flexibility I needed.
The light indicator logic should be:
I would also appreciate to know if my ladder diagram wire numbering is correct. I am not sure I fully understand how wire numbering is applied.
The components are:
- a Green Brook PRR208 -230 VAC DPDT (changeover) 8 pin 10 amp relay with 2 NO and 2 NC switch terminals and base,
- a delay off adjustable timer relay 250 VAC 16amp 50/60 Hz and,
- a self powered current sensor switch adjustable 0.3 ~ 30 amps normally open
- a momentary RED push button switch with both N/O and N/C contact terminal choice
- a momentary GREEN push button switch with both N/O and N/C contact terminal choice
- LED indicator lamps 230-380V 20mA in Red, Blue and GREEN
- 1 x Single gang 13A power socket outlet wired to the main relay - for dust extractor power
- 3 x double gang 13A power socket outlets wired in parallel - for power tool power
- Power source - single phase 240VAC on a 32A rated breaker
- Dust extractor - 1,200 W 230V - max current draw 5.22A
- Auto mode - power tool use (current flow) determines power to dust extractor - Blue light on, RED light off, green light off
- Override mode - Green push button operation latches CR1 relay coil - GREEN light on, Red light off, blue light off
- Stop mode - Red push button cuts power to override circuit putting CR1 relay back to unenergized state - STOP light on, Blue light off, Green light off
