Relay help much appreciated. | on ElectriciansForums
Discuss Relay help much appreciated. in the UK Electrical Forum area at ElectriciansForums.net
M
MrTrance
Evening sparks... i'm a relay virgin and need your help.
First one I need a 12v thermostat to bring a 230v pump on... am I right in saying that in a relay your L & N from fuse spur in the top side, a L & N in the bottom side (output) then an 'a1 + a2' which would be my closed contacts from my 12v stat? What is it I need to ask for in the wholesalers please?
Next one... building inspector said he wants a heater (2kw) coming on with the light in the bathroom. Never heard of this regulation before but its on a granny annex I'm currently wiring. Anyway... so similar to the above relay but the time I'm going to have a 230v signal into some sort of relay to pull the contacts together for the heater? Again what sort of device should I be asking for at the counter.
Muchas Grasias.
12V relay please, with 2 X NO contacts rated to the pump, whatever that may be. Also could I have a 230V relay with 20A contacts (would be nice but would settle for less) oh and can you make that 2 X NO as well. Oh and by the way a nice box to put them in and a couple of bases to go with the relays. Some stuffing glands for the box and several metres of white 1.5sqmm flex. Oh and I forgot, how much is that damaged TP board going for in the corner....... :) - that's usually how my conversations go.
Reply to Relay help much appreciated. in the UK Electrical Forum area at ElectriciansForums.net
This contactor you suggested unfortunately only has two NO switches rather than 1 NC and 1 NO required for the CR3 current sensing bypass...
There's a church in a town near me that has solved the heating problem for most days by building what is essentially a large timber and glass...
