Relocating a consumer unit - Regulations advice needed :) | Page 2 | on ElectriciansForums
Discuss Relocating a consumer unit - Regulations advice needed :) in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
there's an estate near me, built in the 90's. CUs are all mounted drirctly above the downstairs bog at ceiling height. you can't get steps in. only way is to stand on the bog itself.
well, obviously both the positioning of the CU and the bog were on the original design spec. which will , of course, have been done by an architect. nuff said.
i had to sort a socket out on one the other day. now i'm just shy of 14stone, so i had to get the (lady) customer, (around 8stone, wet through) to get on the bog and isolate the relevant breaker. no way am i doing a £50 job and being billed for a new bog.
The last person to have worked on my property seems to have made a mess of things. The consumer unit was relocated, following his advice, to almost ceiling height which is against building regulations as I have only recently found out.
Forgive me if I am reading this wrong, if its a new build? I would not expect to see a consumer unit, as A NEW BUILD, means just that, starting from scratch. Therefore, how can the last person make a mess of things and relocate a consumer unit? If this is a new build extension then the building regs regarding the suggested heights of consumer units do not apply.
Now this begs the question, have you had someone do this installion ,and are now finding out that they ( you) did not know what was required to satisfy the law
Ben
Reply to Relocating a consumer unit - Regulations advice needed :) in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
However it's done, you need to have a guarantee of no sharp/unprotected edges that can damage the insulation. Personally, I'm not that impressed...
The trunking on show there is only big enough for maybe 2 cables…. And a relatively new addition. Having an EICR done would give you an idea of...
