SparkieBusiness
Hi all,
I have a situation where I need to relocate a light switch about 3ft across.
This is due to a doorway being bricked up and the light switch needs putting near the corner.
Due to concrete flooring upstairs I cannot access the cable from above.
I am aware that I can make access to the existing cable within 150mm from the ceiling, join a new cable, go across and come down to the new switch location. But as I need to then bury the cable into the wall what can I use to make the connection between the new and existing cable?
Thanks in advance
Tyrone
Thanks in advance
Tyrone
