Remarkable electric shock I experienced
I experienced an electrical shock while replacing an A/C Fan Coil's 120vac, single phase motor that was above the ceiling grid in an office, while I stood on a fiberglass ladder and having no other voltage, neutral, nor ground point in the electrical shock -It was severe enough to lock me to it and leave blisters on entry and exit points. Here are the details: I was time constrained and in a hurry; and convinced of the concept of the "bird on a high tension wire" not getting shocked, and not troubling with turning off the breaker NOT putting on gloves, I began to strip the Stranded (THHN) "live" wire feed to make the necessary connection to the motor lead, using a wire stripper designed to strip solid copper insulated wire -this requires a little extra "umph" to pull the insulation off the stranded copper wire; so holding the Wire Stripper in my right hand (index Finger touching its metal, uninsulated portion of the Wire Stripper) and my left hand holding the "live" (120vac) wire by its insulated covering, I used my left Thumb against the Wire Stripper for the "umph" to pull the insulation away; at which point I compressed the Stripper to cut the insulation and pressed my thumb against the Wire Stripper to pull the wire apart from the end of the now stripped insulation; at which moment, I became hung to an electric current traveling through my Hands, Arms and Chest. I thought of walking down the ladder, to free myself; but thought I might NOT be able to break loose; so I slung my legs out side ways to cause the ladder to tip out and I fell to the floor, landing unconscious but freed of the shock! It taught me that a single voltage can cause death by electrical shock and the "bird on the wire" is a "false flag" concept.... My thought (as to how that was possible) is that the left Thumb and right index (less than an inch apart on the wire stripper) set up a capacitor circuit and my arms and chest became the dielectric!?!
safe Isolation comes to mind…somewhere you’ve made a contact to earth & shocked…this time you survived next time maybe not so lucky BEWARE!!😎
It was a single wire having 120vac impressed upon my wire-Stripper in which my left hand's Thumb and right hand's index finger touched the Stripper's metal as I cut the insulation -NO other voltage delta NOR ground potential- as the current traveled through my thumb hand arm chest other arm hand and finger...; THAT'S why it is SO remarkable- I will try to upload two photos I took afterwards -showing the blistered Thumb and Index Finger.... The only other possible thought as to how this electrocution was possible is Harmonics impressed in a single voltage source; which can set up a delta-Voltage (Voltage difference) strong enough that the current locked my arms to its travel.
Please tell me where that contact to ground was, as the two blister points -for in and out (and then through my hands, arms, and chest area) were my left thumb and right index Finger which contacted the wire-Stripper as I crimped the insulation and pressed the left Thumb against the Wire Stripper to assist separation!?! The left Thumb and right index Finger were about as far apart as are the feet of a bird sitting on a high tension/voltage wire that everyone has witnessed looking up -That's why this electrocution was so REMARKABLE. Judge me rash, incredibly stupid, it matters NOT to me, what matters to me is why I got shocked doing inessense what birds do all the time..., and I lived to tell the story and begin a dialogue on what has NOT been ever addressed -I have the photographs I took of the blisters I received.
You have been incredibly lucky not to do any more damage....
In fact, you should mention this to a doctor, just in case.
Your analogy of a bird sitting on a wire is flawed.... The cables up there are possibly insulated... not by much, but there will need to be some... just to stop the cables corroding more than anything else.
Ive never actually tested how resistive a fibreglass ladder is..... but unless its marked as being safe f0r live work.... (like insulated screwdrivers) i would't trust it.
I'll try to attach the photographs I took -They show the entry and exit points as my right index Finger and left Thumb -and I can tell you the current traveled from these two point (less than an inch apart -about the distance between a bird's feet in the olden days perched on a high tension wire when NOT all pole hanging wires were insulated) as I held the wire Stripper to remove the outer insulation on a single, live 120vac (thinking I'm as safe as any bird in the field of a single voltage sourced wire...; and, as I mentioned, I could have walked down the FIBREGLASS ladder because NO current flowed through my legs! I lived through the experience and can only explain the Voltage/Potential difference -that had my hands, arms, and chest LOCKED to it and was electrocuting me- had to be due to induced Harmonics that can occur: There then IS a potential difference. It is important that I give a heads up, for my guess is that this has been the death of other senior electrical workers who have been led to believe in the bird on a wire concept -which I now know is a FALSE Flag.
Thanks for responding,
Richard Blankenship
I get the theory on which the OP thought they could depend as birds do indeed sit on live cables without harm, but I've watched a swan electrocute itself when its wingspan reached to cables on approach for landing.
While I get the theory, I'm not sure it applies to human beings dependant on fibreglass ladders to insulate them from the general mass of earth.
Perhaps the OP might have been safe with a huge air gap between them and the ground (or anything else in contact with the ground). Just need to learn how to float or fly.
A lot of overhead lines, particularly HV are uninsulated. Birds sit on them perfectly safely because both feet are on the same wire which is at the same voltage so no current flows through them.
R Blankenship,
mainline,
