REMOTE (via iPHONE?) controls | on ElectriciansForums
Discuss REMOTE (via iPHONE?) controls in the UK Electrical Forum area at ElectriciansForums.net
SPARTYKUS
Is there a reasonably priced product anyone knows of where one can effectively switch the heating on with, in a house 80 miles away, that is equipped with some kind of SIM-powered, relay / contactor filled gadgetry?
We need to be able to provide a solution whereby the electric heating can be remotely controlled.
And no, don't say "ring the neighbours"!
Go on the screwfix website as they seem to have a wireless system for sale.
Mark that looks a poss., basically a auto dialler like on an alarm. I just need to switch a set of seven heaters (all with individual thermostats) on or off, they are all switched at the moment from one switch (through a couple of contactors as quite a large load approaching 40A).
The electronics and IT required to do this are easy enough at a 'system block' level, it's just whether or not someone has manufactured it in a plug and play fashion!
The problem that I can foresee isn't in the electrics/electronics, it's going to be with their ISP. To my mind, it's only going to work if you have a system of fixed IP addresses, and the heating system is going to be, in internet terms anyway, a server which will have to be able to be found on the web. Many ISP's don't allow that kind of arrangement within a standard package.
Reply to REMOTE (via iPHONE?) controls in the UK Electrical Forum area at ElectriciansForums.net
Hi Richard, thanks for your comment. The relay is rated 12A peak. It's also worth noting that a relay contact will perform differently depending...
    • Winner
