removal of main cutout fuse! | Page 8 | on ElectriciansForums
Discuss removal of main cutout fuse! in the UK Electrical Forum area at ElectriciansForums.net
HappyHippyDad
Supporter
Gloucestershire
Hello all,
I think this may be a controversial question, but here goes..
I have passed my domestic installers course and will be getting registered soon (so showing a CU change would be good). I would like to update my consumer unit and have read many of the posts on this site regarding that. I will first try and get the DNO to fit an isolation switch if not then I do not want to work with live tails so pulling the main cutout seems like the option. Lets say for arguments sake that I will get permission by the DNO, thats not really what I want to get into on this thread.
From other threads I think it a very good idea to first assess what type of head it is (cast iron seems one to avoid) and what condition it is in.
Wear electricians gloves.
Test the tails after removal of main fuse to be 100% sure they are not live.
Have main switch off when removing and replacing.
One question is how to make the meter box safe for others whilst I am working inside. Do I just remove the fuse from the main cutout and replace?
This is clearly something that should have been taught during my course, but it wasn't, they just said pull it, which isn't good enough for me.
Any futher advice on removing the main cutout fuse would be most welcome.
Cheers.
Signed it.
The weasels in parliament are very switched on to people power in numbers, especially when the press get involved or if it could mean their jobs are at risk!
Apathy is the death of all progress, so if you can't be arsed signing the petition, then don't complain ever again about this predicament we electricians are faced with!
Reply to removal of main cutout fuse! in the UK Electrical Forum area at ElectriciansForums.net
It’s amazing the number of jobs I go to where the seal has already been cut by someone previously.
I might have got lost here, but the rotary iso is rated at 63A so 25mm armoured still wouldn't make the install satisfactory. Assuming everything...
